ridindirty800
I have a 2003 Ford F-150 and this winter from time to time when you would close the doors the dome light and the light on the back of the truck would not go off. Even when I hit my key less lock to lock the doors they would stay on. It seems to only do it when there is moisture present! Wondering if there is a sensor somewhere on one of the doors to check and see if it is getting wet or going bad? I had to pull the fuse out so my battery wouldnt drain! Any info of what to check would be great thanks
