Fox shock adjustment
bobsledder
My neice has a fox shock on the rear of her cat skid. There is a brass fitting at the bottom of the shocks side. In this brass fitting there is a chrome screw head that is screwed in all the way. Is this a adjusting screw or is this a port for changing the oil? I worked on this sled and she rode it last night and it was much better for her. However it nags at me that with everything set for her (very small) I cant get the back of the skid to bottom out even with my big ars on it. Thanks
Bob
motor_slut
As Garageguy said that is an air needle port for filling the shock with Nitrogen after a rebuild. You will probably need new lighter springs.
Per your previously posted thread, did you check & adjust the rear spring adjuster blocks? There are 3 settings, remember to drop from the highest to the lowest. For a rider of her weight, set them on the 1st (lowest) setting. If that doesn't work out, do as mikedrh suggested & have the shock revalved for a softer ride.-Mezz
