Is it true that an adult puts off about the heat of a 100 watt light bulb, yes I understand some are dimmer then others.
Yep, in the 80s last week now this! Funny you didn't mention the two feet of snow at Flagstaff! (Now that's gotta hurt!)Forecasted high at the Houghton County Airport = 78 today
Forecasted high for Phoenix (AZ) = 60 today
Can't remember a time where that has happened!
.Nearly Four Feet of Snow Gone in Two Weeks!
In the wake of an early March winter storm we reached a maximum snow depth for the season of 47 inches here at the National Weather Service on the morning of March 4th. Exactly two weeks later on the morning of March 18th, in the grip of unprecedented record warm temperatures, our snow depth was reduced to little more than a trace. Surprisingly with the rapid snowmelt, no flooding has been reported thus far across west and central Upper Michigan. A big reason we escaped flooding was the lack of significant rainfall which occurred during the rapid snowmelt.
The record warming trend is expected to continue at least into the middle part of this week before a frontal passage ushers in slightly cooler temps for the end of the week. But given the lack of additional significant snowmelt runoff, area rivers and streams should see only subtle rises as levels are expected to remain below bankfull
The world turned upside down on its axes one night while we were all sleeping and the heat rises to the top. That's my answer. (No I have not been drinking).
I saw that, I thought I'd see if someone else caught it. Score one for the beagle!When I read the above quote I was (am) sure PR1 meant axis, not axes. And then I thought maybe PR1 did it on purpose for the person the thread was started for; frnash. But the funniest part is that our local spelling and grammar coach, frnash, didn't even catch it. BTW, I'm still loving the lessons daily, thank you.
I sure "wooded"!I believe our learned one, is too busy, trying to get that poor excuse of a furnace going full blast. Otherwise, he wooded caught that one for sure!
Axis: singular, axes: plural -- (also plural for [woodsman's/lumberman's] ax or axe [variant of ax])!.
The last I checked, the earth had only one (rotational axis), ergo: axis!
I sure "wooded"!
whats the snow bowl and where is it 56in wowArizona snowbowl: 56"whats the snow bowl and where is it 56in wow
Bellemont: 28.4"
Flagstaff: 26 - 29"
Prescott area: 21 - 27"
Pinetop/Lakeside: 26"
Williams: 24.7"
Fort Valley: 24"
Mountainaire: 22"
Parks: 22"
Pine: 22"
Kachina Village: 21"
Forest Lakes: 20"
Mormon Lake: 17.5"
Sedona area: 10 - 17"
Show Low: 8 - 14"
Crown King: 14.8"
Linden: 13"
McNary: 12.5"
Payson: 12.5"
Heber/Overgaard: 10"
Grand Canyon: 6"
Jerome: 5.5"
Alpine: 5"
Jacob Lake: 5"
Piñon: 5"
Concho: 4:
Cottonwood: 3"
Eagar: 1"
Window Rock: 1"
Meanwhile, Marquete, MI NWS says:
Click → The Arizona Snowbowl. On the San Francisco Peaks, 14 miles out of Flagstaff, base elevation 9,200 ft., summit elevation 11,500 ft. The elevation is the main reason for the amount of snow. (Flagstaff itself is at an elevation of 6900 ft.)whats the snow bowl and where is it 56in wow
just so you know most adults put off about 800 btu thats why your AC dont work at the 4th of july party most houses are set for cooling for 2 people per bedroom just so you knowLet's blame El Nino and La Nina. That has been the scape goat for years. John, not sure on one of the rules so I will put this out there for everyone, Does anyone think that all the heat man creates along with things such as Volcanoes, solar flares, forest fires, etc. That the planet has to be getting hotter. Everything we do creates heat, even air conditioning, how can the planet not be getting warmer? Can heat dissapate into the atmosphere? Is the heat held in some how? (coffee is kicking in). Is it true that an adult puts off about the heat of a 100 watt light bulb, yes I understand some are dimmer then others.
Well I'm heading that way in 2 weeks and hope I can experience some of that dry desert heat. Though I have noticed the humidity levels are higher with the cool (cold ) weather of late.
