Hey Guys, My 07' IQ 600 cfi gauge shows empty and has an "F" on the screen. Tank is almost full. The last few rides of the year it would go back and forth, now its still shows empty. ? Any ideas smarties ! thanks
I don't have one but one of the guys has an 07 600 CFI Switchback and he was having the same problem. He took it to the dealer and it was an issue inside the tank with either the float and/or sensor that was causing the problem.
I have figured out the problem, thanks to swampcat the float was full of gas. I pulled the tank off to access the sending unit, pulled out the unit with float and found pin hole in corner of float. Took it to work and filled hole with 3M 2-part epoxy and going to give it a whirl. sweet
Now imagine trying to do that through the filler hole. Being a old tennacious shade tree mechanic,getting the float off the arm,sealed up,tested & reinstalled, NOW THAT WAS A HOOT. Glad you found it.
I called the dealer 2 days ago and he ran my vin # and said there was only a hose routing check to be made for my sled. So far anyway, now that I have it fixed, it works.
