Gasoline is readily available and routinely used in most households. In spite of the routine use of gasoline, many people are unaware of or unappreciative of the dangers of gasoline. Gasoline is dangerous because it is highly volatile – the fumes are capable of ignition up to 12 feet away from a pooled source. This inherent danger is further multiplied by its explosive potential. Flammables burn at close to room temperature (100 degrees F), when they are near a spark, flame, or even static electricity. It can float on water and may spread long distances, making ignition and flash back possible. Gasoline vapor is highly explosive and may ignite as a “fireball” with a temperature of 15,000 degrees F.
