Glue
eyeman
My nephew is coming home from Afghanistan tomorrow and I'm trying to finish up a hood replacement on his air cooled 1995 Z440. The new hood is from a liquid cooled sled and does not have the cooling air scoop. I cut/ground the old scoop from his old hood and cut the air holes is the new, now I need to glue it onto the new hood. Anybody know what the brown/red tough tough glue that the factory uses is? The scoop is glued under the three rectangular holes directly above the bright green with the orange tail of the Z going through it.
doo_dr
Epoxy
I have seen people use PL400, JB weld, and RTV 2 part epoxy to adhere the shroud back on the hood. Three things to remember: clean both surfaces to get all grease and oil. rough up both side with very coarse sand/grinding app's. Glue and tape down the shroud in the warmest place you can (most of this stuff doesn't work in the cold). I like the PL idea the best but have not seen how long it last.
eyeman
doo dr, that all makes good sense, but I'd still like to use the factory stuff. It took everything in my toolbox from grinders to the sawzall to remove it. I know it would hold forever. Thanks.
doo_dr
3M
Start looking. I don't think that glue comes in anything but a industrial style air powered calking gun. The last time I was at CAT (years ago) that is how they had it. 3M may make a similar product you can find at the auto parts store!!!
phazerpilot
3m,norton,sem and lord fusor all make fast set epoxies for the application you are doing but they are not cheap. most automotive paint suppliers will carry a least one brand of them. all use a 2 plunger caulking gun with a static mixer on cartridge
rp7x
get stuck
if you stop at a local body shop and tell them why you need this they will be happy to spend a minute to help , tell your nephew thanks
big_bill
You want a plastic weld epoxy. I've used this in the past with great result. Not expensive either.
snodogg
panel bonding adhesive, like previous posts, get from 3M at automotive paint supplier, better off stoping at the body shop and flippin them a few bucks to do it
eyeman
Body Shop Supply has 3M products - that's where I'll go. Thanks everybody. Actually Marina PFC Colin Pinard thanks you.
