goggle fogging and scotts fan
cobraindy
I have a fair amount of fogging issues. I use the no fog mask which helps alot but I stll fog. I was thinkins of trying the scott fan. Does anyone have any experence with these? Also will it work with the scotts turbo flow xis?
pez
get a different pair of goggles that fit better. Another trick I just learned was to breath with lower lip tucked under top lip when stopped.
reiley99
I bought 100% goggles this they are the worst goggles I've ever owned I know a couple other guys feel the same as me.
mjbiersc
I have been using the goggle fan for a couple years now, it helps a lot if your sweating and the heat from your head is causing the goggles to fog. If they are fogging because your goggles are not making a good seal around your nose and keeping your breath out, then the fan will not help much.
