Stupid question here. Will the Garmin show your location in relation to trails/terrain? I have the Polaris app on my phone but of course it is useless most places out on the trails where there is no signal. Don't know much about the Garmin system. Thanks.
Yes it will show you location, and it will show trails, the relationship between the 2 is easy to see if within a few miles, difficult to see if it is 30 miles. If not on a trail, you must determine best route, it only give a straight line, it does not account for terrain that you must circle to find the trail.
On a Street map system it has millions of "way points" preprogrammed, in example addresses. you designate a Way point, and drive the car, directed by the Garmin, via streets, (trails) to the address.
On sled maps there are very few "WayPoints", you can put them in, but these are not pre programmed in, in example, Creek A, or River B. There may be a place to get gas, preprogrammed, but these will be few "Waypoints" as compared to "Street Maps"
Yes there is a learning curve.
My problem is missing trail turns, I over run them by a mile or 2, turn around and go back.
With the GPS, I can watch/see the trail approaching, I can slow and watch the screen, no missed turn.
Getting into and out of a town for a burger, we end up cutting thru yards, trying to find the trail to get out of town.
The search for the burger, does not allow me to take note of the trail location.
Have you ever come to a road, and no trail across the road? Now you must travel the road to the trail, do you go right or left, tracks in both directions, hopefully the GPS will show which direction to go, to the trail.
The Rider X works if within the cell phones range, if not in range, then you must add a step to load the Rider X map to the phone.
Consult Rider X on specifics.
Garmin works from satellites, and has 1 limitation and that is that it must receive the signal from multiple satellites, in simple terms, GPS does not work indoors, under a roof.
Satellite are owned and operated by the Department of Defense and were given to the worlds user, by the US. Highly accurate if using better equipment, Garmin is certainly accurate to within 10 meters, likely better, Surveying gear is accurate to 1/10 of a meter.
