I have a XOG. Last year I learned that it doesn't work to use the cigarette type adaptors because the connection just isn't that good and the Xog was in a constant mode of re-boot because of power interuptions. After I went through the trouble of hardwiring - with a fuse-all the way from the bat to the unit I found that the mount for the XOG just couldn't stand the bouncing and sooner or later will fall off. Maybe your model is different and has a better mounting plan. This year I am not even going through the bother of mounting and wiring. I will just carry it in my pocket. I wish someone would just make this a factory option with a nice big color screen. I bet there would be a lot of takers. Good luck.
I just run a 1 into 2 audio pigtail (Radio Shack) from my shield plug to the shield and the garmin. I just put the GPS in the tank bag so I can see it and goes into the motel easily at the end of the ride.
Works fine on the Viper with electric start.
This is how I mounted my XOG. no problems. I would never mount a GPS on the handle bars the way I ride.
I have the XOG with the Ram mount. Had the same problem with the connection at the cigarette lighter coming loose. Just wrapped some electrical tape on plug above where the contacts are. It fits snug in the cigarette adaptor now, and works fine. Quick an easy fix.
That is kind of the way I mounted my XOG on my Vector. I just don't trust the plastic mounting tabs. Especially when they get cold and brittle. If a person ever starts getting a little aggressive and you hit a big bump or two you might look down and see no GPS. Of course it is possible that Polarises ride so smooth and soak up the bumps so much better than the Yamis a person doesn't have to worry about such things. Just kidding. I just don't want anyone to lose their GPS.
