Bkboats doesnt have one, Kingblunder had one w/o the helix and spring but i requested a photo and have heard nothing. I checked a place in Proctor, Mn; and in Victoria, nothing.
Still looking if anyone has any ideas. Thanks, Ben
Not many of the stock 10" clutches available anymore. I too have been looking for one. I'm sure a lot of guys have them laying around their garages, but that does not help. 10.4 is actually a better setup (improved low end) if your sled is completely stock, but will require that you use a different belt and slightly modify your footrests to install the belt with larger diameter clutch.
The clutch was part number 0726-195 and is superceded to 0726-254. Cat is showing availability of 2-3. So if that is correct, expect it at your dealer Tues or Wed of next week. That is if you order one by Fri AM.
