Head lamp light bulb holder
timo
my back up sled blew a bulb so I replaced both of them. 99 mxz 600. Now I can't get the holder to fit back on the harness. Its a zinc plated yellow thing that is circular in shape about the size of the palm of your hand. The middle is cut out with these tabs that extrude out from it. I imagine you just kind of put it on the harness and turn and then it will lock into place. Well one hour later I can't get even get one on. Any one have any ideas-shortcuts that can get this on.
Thanks in advance.
Banjo Man
I could be wrong but I just did this on an old Polaris and there is a wire pin that holds the bulb and harness in place. You stick it through the back and it catches the 2 notches on the front side.
Hope this helps.
timo
that's not it. no pin. of course when I took these holders off i didn't really pay attention to how they were on there. it's like you got turn these holders on the harness and then the tabs that are cut into the piece some how lock the light into place. something like that. argh!!!
thanks for the response though.
