2002 mzx 500 Fan
Should the voltage drop when giving gas. At idle the voltage is at 12.6 at the head lights. When I give it gas it drops to 9.6 and blows my head light and tail light bulbs. The bolt holes for the V.R. were stripped out so I put bigger bolts in to ground it hoping this would fix it. Also noticed the gauge lights go out when giving it gas.
I just put a new voltage regulator on and it does the same thing. At Idel it 12.4 to 12.6 when given gas it drops to 9.5 and blows the bulbs. I clean the surface were its mounted also.
Any Help with this thanks..
