Where should I wire this into? 1996 Polaris Ultra. Thanks
S soxfan3 Member Dec 21, 2012 #2 On my 98 poo, I connected to the wire for the hand warmer on the bars. Start sled check for power with test light, splice into it for power. Connect ground to anywhere convenient. I think mine is on bar riser bolt. Works fine.
S soxfan3 Member Dec 21, 2012 #4 Make sure you get the wire that is hot all the time. Otherwise the helmet will only work when handbar heater is on.
