tritonmark
Rode last weekend in the snow and sheild was iceing up on me. My question is would a newer hjc with a electric sheild for around $150 work or go with a modular type helmet that costs more?
Man, I hope you're right. I'm switching from my Bombardier Modular 2 to an HJC MX helmet. As for the thread starter, my experience is that the Bombardier may work for someone who never sweats, but I'm not that guy.u just need to get the heat/breath away from your shield, try a face mask with a breath guard/deflector on it, maybe crack your sheild a little. If all else fails use a moto cross helmet with double lens goggles, it will never frost up
I have a heated shield,bought it after I went over the handle bars from my shield icing over. I will never go back. I'll probably buy a motocross style if I do a lot more off trail riding. The cord is always hot. The only way to find out if its not working is to put a voltage meter on it. If it ices up, it isn't working. There will be instructions on which wires to splice into on your particular sled or search for the answer on here. The cord "tying" you to the sled is something you won't notice. The only problem was when it came out of my helmet and grounded to the sled, that will shut the motor down.
My advice would be to buy it. I don't wear the breathbox and I haven't for 5 years.
So next time I go down the trail and see someone licking the inside of their shield I shouldn't worry, they are just checking to see if is working? Sorry LMAO at the visual.I wear an HJC with electric shield and never get frosted up ever. No matter what. I hardly even notice the cord hanging by me. Another way you can check to see if it works is unplug it from your helmet and stick your tongue on it, you'll feel a very, very, light tingling sensation and then you know its working. I do it and you won't get electrolucted and it doesn't hurt.
… I wear a balaclave [sic] (sp Nash?) under my motorsross [sic] helmet and make sure there is no exsposed [sic] skin when I put on the goggles …
