Last March motor burned down with a hole in the mag side piston. Did a top end rebuild this summer with 2 new pistons. I thought the problem was because oil pump set slightly lean and running wot at -10. Took it out this morning for a 10 mi ride and sled shut off at stop sign. Took out plugs and I see a crater starting to form on the mag side piston. I was running extra oil in the fuel for break-in. Carbs were cleaned and set to factory specs during rebuilt. Anyone have any ideas on what I should do now?
