honda fourtrax atv brake ?
L
lenny
I have an old 86 Honda Fourtrax atv. The front brakes are not working. I bought it with no shoes in the front drums and now trying to get brakes back. I first starter to check the rest of the system by open master cylinder cap to find a bunch of gunk. I cleaned it out as good as I can and tried to pump some fluid through it to clean it out on the inside before pumping the crap into the entire system. With the brake line off of the master cylinder I cannot get brake fluid to pump out by squeezing the brake lever, I mean a tad bit will very slowly drip out. I would think it should blow out of there. I think I could blow air back through the master cylinder or pull the piston and check the seal, any ideas?
