lakes of north
Had a bearing failure on my Yamaha SXR 600 sprocket drive shaft.Speedo key fits into the end of the shaft.The key broke off inside the end of the shaft.I've gone through three metal specific drill bits to try and extract as much of the broken key as possible out of the end of the shaft.I can get the new key in about 3/8" of an inch which isn't all the way in, but I also round the edges of the shaft hole in the process of trying to drill out the broken key parts.The key has 4 flats and is about 3" in length.I tried using JB weld to hold the key in place inside the shaft, work for about 50 miles but the torque on the shaft finally wore it out.The JB weld worked but is to brittle to last.Does anyone know a product that would hold and be more pliable as to be able to handle the torque on the shaft?Can't find an e-z out that small of a diameter to fit in the end of the shaft to get remaining pieces of broken key out.Didn't take shaft out to drill, used compact right angle drill.There has to be some way to rigg this to make my speedo work again.Doesn't have to be pretty. FIXED IT! RESPONSE IS THE LAST ONE BELOW.
