This is for you heating/cooling folks. I have a rental that I include electric/water in the rent. The rental is 1100 sq.ft. on the main level with a 600 sq.ft. basement used for storage. Okay, what I have is a newer furnace (2009) with the original air conditioning and duct work above it. The compressor (or whatever it is called that sits outside with the fan and fins) is a 1987 model sized for this area. It works fine. My question is, "Are the newer units so much more efficient that if I changed out the compressor with 2013 model, what would I see in time for a payback in savings and to cover the new compressor.?" "Is it worth swapping out or wait till the 1987 unit dies?" They will run the air all summer I suspect. rental is located in Grand Haven, MI. (lower western MI) if that helps with climate info.
