skeeter2010
I have an 09 600 Dragon IQ
I decided to stud the track 144 up the middle I weight 200 LBS. The sled has Dual 8" Slim Jim duallies on it. It really pushing through the corners I have adjusted the torsion springs from low to Medium and that did help, I went to adjust the limiter strap however, it has no adjustment this skid has just one strap and no additional holes for adjustment ( I did check under the washer just to make sure) The sled does corner good if you are riding hard but not at a resonable pace. Does anyone have any recommendations on how to correct the push.
I kind was thinking about adjusting the track shock looser to see if that helps
Thanks for the input
Scott
Scott
