In Michigan You really should put a dry well in for your drain. This will keep up with the snow melt. I made my own with <font color="ff0000">•</font><font color="ff0000">•</font><font color="ff0000">•</font><font color="ff0000">•</font> gallon plastic drum. Drilled a million holes in it. I put some pea gravel in it to keep it in the ground and keep it from colapsing. It also helps water to filter out into the ground. Backfilled with sand. Kinda like a mini septic tank and drain field combined. get a decent drain for garages/barns. Not a wimpy house drain. Heated floors ARE SWEET. I install A few in my day. Run it off a hot water heater. My system is simple, closed loop (no anti freeze in it) preasure tank, tubing, hot water heater, circulation pump, some misc. copper tubing and a mixer valve. This is a must for the shop. Plug in in fall, unplug in spring. Beats a sink hands down. Building inspector???? Yea right, more like property tax raiser. Don't need to pay more taxes for being comfortable in the garage. You can Google the "how to do" for free.
