Indy 500 Torque Specs
If anyone has the Torque Specs for a 1999 Indy 500 Fuji 488 liquid cooled can you please help out.
Both gears in chain case -
Intake bolts -
Exhaust bolts -
Cylinder nuts -
Head bolts -
Primary Clutch -
Also, need to know what the idle is suppose to be set at -
Thanks.
motor_slut
Both gears in chain case - Tight but no too tight on the lower one
Intake bolts - Tight
Exhaust bolts - Tight
Cylinder nuts - 30 ft-lbs
Head bolts - 22ft-lbs
Primary Clutch - 50 ft-lbs
Also, need to know what the idle is suppose to be set at - 1500ish
