Installing new stator in 1998 Yamaha vmax sx 700
cdcook22
I have a bit of a problem. Its my first stator job and it was a lot of work getting down to the part where the actual stator comes off and I got in a hurry and forgot to mark the position of the old stator. It mounts with three screws and I think there is enough slack in the wiring that this could possibly be mounted in 2 or 3 different positions. Am I out of luck? I can't find any info anywhere about how it should be positioned. Or will it only bolt on one way? I just have one screw holding it up right now because I wanted more info before I put this thing back together. Can anyone help?
kip
cdcook22, the stator will only go in one way so no need to worry. I'm suprised you were able to get the rotor off. I'm guessing you have pullers. So to answer your question it will only mount one way. Good Luck! Kip
Pat's Yamaha
Greenland,MI 49929
906-883-3536
Authorized Yamaha Dealer
cdcook22
Hey thanks a lot! I put the sled back together and she fired right up and seemed to run better and the headlight seemed brighter! Now if we can just get some snow!
