700classic
Replacing track on V-Max, while I have the chaincase open I'm going to replace the jackshaft bearings also. Have the Secondary off, set screws loose on bearing. I see a snap ring on inboard side of brake rotor. What else is there to remove to get shaft out and which direction do you go with the shaft to remove it? Does the caliper need to be removed? The bearings don't seem bad, but replacing them for peace of mind(what little mind is left). Thanks in advance for any input!
