Im wanting to hook up my GPS and wanted to know if anyone knows if there is an accessory connector under the hood that I can tap into? Or should I just start poking around looking for any plug that has power? The sled is a 2011 Polaris 600 CFI. Thanks!
Why would you want to have your GPS power switched? If you run a line from the battery, the battery works as a filter and evens out any pulse of the current plus it will stay running when you shut down the sled. It is more work to run the line but you can fuse it and then the GPS will stay on when you turn the sled off.
