polarisrider - ok, I found that picture from you on another thread. Did you put anything on the backside of the dash for strength when you mounted your GPS where you did? Also, when you mount it like that, is it basically at the right angle towards you, like the speedo gauge? Just trying to figure out if I should mount mine like you did or buy the whole RAM kit so I can adjust it.
