Mudjacking
catalac
Have any of you ever had any mudjacking done to your drive or sidewalk?
I was just wondering if its worth it, or would it be better to tear up and lay new concrete.
Thanks
Im sorry, I meant to put this in the Off Topic section.
t_man
Had it done many times for commercial property, but not at a home. Works very well as long as the underlying cause of the problem has been dealt with. For example, if poor drainage caused the problem but has not been resolved the area will sink again in the future. I found most contractors were pretty good at assessing the situation and advising whether it would be a long term solution or not. Definitely worth pursuing.
Be aware that in most cases they are going to core drill through the concrete to pump below it so there will be a visible repair. Not a big deal but make sure you understand what it will look like after.
catalac
Thanks t man, I think it is just from settling. We built the house about 13 years ago and it is just starting to do this. Probably going to have this done and if it does't work then will just tear it out.
Thanks
