I just talked to a guy from Munising and he said Kemosabee's was closed and for sale again (over $1,000,000)
Maybe they are opening it up for the winter to make some cash?
New info
Update,,,
Kemosabe Cabins are now called Knotty Pines Resort. There was been a lot of work done and still more to come. We have had to do some work on the place since it sat so long but we now have the lower unit which was units 5 and 6 all done. Presently we are combining them as one unit since the glass door can only be locked on the inside. Since we have change the name of the place we are also changing the name of the units. So the lower units which were 5 & 6 are now called the Hemlock and the Tamarack cabins. The upper units 1, 2 & 3 are called (1) White Pine (2) Red Pine (3) Jack Pine cabins. In the lower units we just put new 32" flat screen tvs in there which we will be putting in all the cabins as we finish up remodeling. The Red Pine cabin is getting a whole new look and will be the model for the rest of the upper units. We are working on a website and we will post as soon as it is up and running. The new number which is really the old local number to the place is 906-387-4538. There is still a bit of work to do but our goal is to have it as good as it was before and hopefully better. Like stated before the lower unit is reay for reservations. Since the lower unit is going to be a combine unit as a rental it will have two of everything. Two tvs, batherooms with showers only, kitchens. The sleeping is 6 comfortably which consist of 3 double beds and 3 top single beds, but will hold up to 11 because along with the double beds there are 2 pull out couches. We will rent that unit for a flat rate of $180 a night up to 6 people and $30 per person after that.
Forgot to mention that we are working on putting satalite tv in and also will be WIFI in the cabins.
If you call Please leave a message. Since the place has work to be done there is not always some one in the office. We are open to any comments or suggestions you may have and email them to
knottypinesresorts@gmail.com
We have also started a new Facebook page:
http://www.facebook.com/KnottyPineResortLLC, there are some updated pictures for some of the renovations that have been completed. It will be updated as work is completed.
