cardinal43
I have a 2 year old home. Central AC (carrier) was brand new 2 years ago. Our AC ran fine 3 weeks ago, but this week, would only blow room temp air. The compressor and the fan all work normally, but just didn't remove any heat from the air or blow cold air.
I had a local ac guy stop buy and he saw that the copper tubing that goes into the AC unit outside, was covered in coolant. ( I did see this and it was definitley a dirty oily substance on the copper tube).
He said that someone must have bumped the copper tube and caused a leak (could have been one of the kids). He said he can fix the copper tube. He said that the remaining coolant needs to be removed, then the system needs to be flushed with nitrogen, and then refilled. He wants to charge me $36 per lb for the coolant and said my sysetm will take 8 lbs.
He said labor to fix the pipe, refill the system, and materials for the coolant will run me $600.
Does this sound legit?
