Need help ASAP - Please
600_RMK_144
Got a guy coming tomorrow to buy the RMK (time for a 155"?). Out in the garage as I type. Had to swap out the jets, no issues. Done. Went to do the weights, put the clutch tool in secondary (loosen up belt). Pulled the clutch tool back out and secondary is loose on the bolt. Can move it back and forth. Hope I didn't F something serious up. Thanks for the help!
srt20
It's supposed to slide on the shaft. If it was tight, you would burn through belts really really fast.
I'm talking a little bit, not a 1/2". The bolt is tight, right? Small bolt, DOESNT need to be torqued to 80lbs.
600_RMK_144
Ok, that makes sense. Guess I've never pulled on it before. Yes, bolt is tight, has some play but not excessive. Damn I thought I was in trouble!!!
