Need some info for a part name-Supersport
Well summertime is here and playing with the new toy got me into trouble. I dropped/lost a piece off the choke trying to get the choke switch on better. I was hoping you guys will know what part I am looking for....
It is a piece of threaded plastic that the choke nut goes over to hold the choke switch there. Is this the choke washer described here? (Parts 18&19)
http://partsfinder.onlinemicrofiche...Polaris_OEM/PolarisSnow.asp?Type=13&A=632&B=6
Thanks for any help. I can try to describe it better if need be!
sjshaner
If it is the washer that goes over the threads on part 12 and is behind the nut part 19 then part 18 is what you dropped. it is just a washer and you could pick up a steel one at the hardware store. It wont match but it would work. If, however, this is a brand new toy that you want to keep 100% original then order it up. If it was threaded on the choke body (part 12) BEHIND THE DASH then that is not it and it may only be available as part of the choke. Check with a local dealer, they may have one off of a bad choke they could sell you.
I got both parts and both were wrong luckily I found the pieces I needed laying in the bottom of the pan a few days later LOL
