What is the price for an "expensive" battery? $50??
I tried starting my sled and it does not turn over or move the guages when i press the set button. I have a battery maintainer on it, but after a day and half it still shows a red light and is not charging. What kind of battery and price do you recommend for the sled?
how old is your battery ???
sounds to me like its completely dead and the charger does not sense any voltage to turn on
i would try hooking up a 9 volt battery to your battery while the charger is plugged in and hooked up
see if the red light stops flashing and stays on
these newer battery chargers have to sense some kind of voltage to turn on
once the red light stays on you can remove the 9 volt and let it charge away untill green light comes on
unless your battery is 5 or so years old just replace it
hope this helps
Deka isn't its own company, they're made by East Penn. That's not to say that East Penn doesn't make the powersports batteries you're referring to, but if they do they probably make them to different specs, as you say.I got 11 seasons on the original Yuasa in a 2006 Yamaha Vector before I replaced it. Coming into the 8th season on the original Yuasa in a 2014 Ski Doo 800, still starting strong and running good. That's reason enough for me to stick with the OEM Yuasa, just don't buy from a dealer, better prices can usually be found elsewhere for the exact same battery.
I think Deka makes the "AGM Powersports" batteries found at places like Fleet Farm, etc.?
They only seem to last 2-3 years, maybe 4, maintaining them the same way I've always maintained the Yuasas......leave the batteries in the sleds all summer in the trailer, put the tender on for a few days at a time about 2-3 times over the summer/fall. I do understand that Deka makes batteries to different specs for different distributors, that could be a reason why some Deka's don't last.
I got an interstate battery for $110 and it is starting now. The guy who installed it said interstate also makes yuasa, dont know what the difference is between interstate and yuasa in terms of quality....if it matters
