New sled
scott_b
When is the new sled coming in?
Or is it already there and you don't want to show it before the forced induction is installed...
cheetah
new sled
John,
Make sure you check the following.
Pull cord it rubs on selenoid
Purchase the goggle bag it fills the hole behind the handlebars
When putting your side panels back on double check you get the tabs in correctly, or their is a gap
Place your spare belt under the seat
If you put on Powerpros ski's you will need to grind off all the little nibs on the bottom of the ski pad in order to fit
swap out the stock front bumber with the other one cat has
I have a XF SP 800 High Country, and these are the items I observed.
Thx
Mark
Admin
Administrator
Thanks for all the great tips Mark.
I will be sure to check to make sure the starter chord is not rubbing on the solenoid. The sled did come with the goggle/glove warmer on it and for now I plan to keep the stock skis on them, but will be sure to heed your advice if I put the powder pros on it.
The spare belt is already under the seat, but am I seeing things right, you need a torx head to remove the seat?
