Nytro Turbo's
Need some good information on turbos for the 2013 Nytro XTX. Between these brands (Push, MPI, MCX, Impulse) which one will be the best to run at all elevations? I know the mcx turbo has a built-in boost compensation system but, what do the other brands offer for running at sea level? I’ve heard that MPI will be the new turbo supplier for 2013 Yamaha’s, is this true? Anyone ever run the MPI kit or did MPI just start making them?
Anyone from Pat's Yamaha in Greenland have any info?
Received some good info over on snowest, but I want to know what riders up north think about them and if they are worth the $$$ compared to the new Cat 1100 Turbo??
scott_b
Not sure how many here are playing with boost at lower elevations, may want to ask this over on Totallyamaha.com. There is a section just for boosted sleds.
srt20
The big dogs use Impulse.....adjustable boost as Im sure most of the other good brands have adjustable boost as well.
thebreeze
It depends if you lower compression, or have a tolerance for paying for high octane fuel. Even at low boost, it will be a fun sled.
