mjkaliszak
I have the same issue ( Oil Pump question)with the 600HO I have. The crank was changed along with a top end and during the first 500 miles I'm burning 2 quarts per 140-150 miles. Do the oil pumps fail to full flow ? I have heard that they do. How can you test or check the pump. The motor is running too fat, the plugs are black and the piston wash is too black. I have had the carbs apart and motor compartment disassembled and can't find a leaking oil line or carb problem anywhere. Messed with the jet needles and fuel screw and I can't tune the low RPM hesitation out. I find it hard to believe that I would have pilot jet problems in both carbs at the same time. With the black tar plugs and excess piston wash things don't add up. The fuel screws are good & sharp on the ends the hole does not have blockage.Any advise is helpful, I'm ready to pull my hair out.
