Polaris Fusion fuel gauge trouble
soxfan3
2006 Fusion 7oo CFI - FULL tank of fuel. Gauge will work for a while (10-15miles), then start flashing low fuel, then go out completely. Stays that way for a while, then might come back after stopping for a while, and then goes away again. Also the trip meter will change, acts like you hit the green mode button when you didn't. Loose wire? Bad ground? I read something about the vent tube w/ a one-way relief valve being replaced backwords if/when the tank recall was done which would cause too much pressure in tank. Which tube is this? The one out of the front top of tank with a little orange cap & tube? Anybody else have this & been able to figure it out? thanks
I have a 06 also and they had a recall on this issue , look inside the tank and see if the wire and float are still connected , when it's all fixed they might have to reset the elec. fuel gage ?
