polaris tps tool
snootbiscuit
thanks in advance!! hey dudes, I thought I had seen this somewhere before? that you could make up your own tool for setting tps on a cfi ? I thought it involved a 9 volt battery??? any info would be greatly appreciated!!!!
prowrench
Just need 5v dc voltage regulator radio shack # 276-1770. Also get 9v battery leads from radio shack. Then just wire it up, hook to tps connector on sled and hold throttle to the bar. You need a dvom to check the voltage. Honestly i can't remeber exactly how i hooked it up to the sled connector, i just figured out which wires were doing what. Check hardcoresledder.com for more info.
