Posting pictures
Tracker
so I ran a bunch of tests....it turns out the resolution and size matter for posting....i live in little Waco so I took a pic of the most fabulous ELOTES you will ever taste off of the food truck.....what I found is the bytes HAVE to be larger in the back and the resolution cannot be over this amount....i might be able to tweak it more so I will jack with it to find maximum but this is what I got so far....the 1st pic will b correct side up with the larger is in the back....the resolution is to about max....then the second will be sideways and I will show you the settings.....the larger is in back but resolution to much....this way you can check each picture you take on an apple or Droid and both shall post here right side up and swimmingly.....all will b happy if you can learn this...so here it is...i hope this helps us all....and Gary I appleogize...we were both right
Ps....ELOTES....its corn off the cob with mayo and goat cheese grated finely with the hottest pepper sprinklings they have...no idea what the pepper is on top but that little amount will set you free and 1/4 box of tissues for forehead sweat.....IT AM GONNA BE GOOD WITH A SAMMICH
Carbide
I have tried dozens of times uploading pics from my phone. No matter what I try, no matter the size I get...Upload of file failed.
Never had any of these troubles on any other forum. Oh well...
Tracker
Ok...thats an easy one....open settings....upper right side left of log out....then click on general settings.....i posted a pic....then go all the way down and turn on the full editor.....check the box that says enhanced interface ....full WYSIWYG editing ....see if that works....but log off and restart phone...don't forget my settings as well....you should be good to go brother....let me know because there might b one other thing to do as well
