[FONT=Verdana,Arial,Helvetica][FONT=Verdana,Arial,Helvetica]...[/FONT][/FONT]
[FONT=Verdana,Arial,Helvetica]Since re-insulating the attic and adopting this tactic, my "Equal Payment Plan", based on a 12 month rolling average electric bill has gone from $302.00 in October 2007 to $99.00 today! ...[/FONT]
[FONT=Verdana,Arial,Helvetica]I have had a number of programmable thermostats over the years. I have been most pleased with my current one: a RiteTemp model 8082C (sadly it is no longer available), it gives you a choice of either two or six time periods for each day. The time periods must be set when the 'stat is set to heat, then the same time periods are also used when set to cool (or automatic). Of course there are different temperature settings for each of those time periods for heating and cooling. I am using six periods x 7 days, with the same temperature settings in the various periods on all weekdays, and I use a second set of six temperature settings for Saturday & Sunday. The six periods per day for each of seven days has been the most versatile and useful for me, although that does make it a bit tedious to set.[/FONT]
[/FONT]Mine has a similar feature, but fortunately I can turn it off! I prefer for the 'stat to set a new target temperature at the time I have programmed, rather than trying to reach that setting at a given time when it "thinks" I want that target to be reached. It just would not do for it to start running the A/C "early" — before the end of my "On Peak" period, for example!
