How long will 500 gallons of propane last?
Hmmm my 3600 sq. ft. house will probably burn about 600-700 gallons December to December & I have a 1000 gallon tank. I'm a lot further north than you but no idea if my useage is conservative or not keep her at 67 degrees but when that sun swings west we get hot. I also burn a lot of wood in the fireplace stove insert. Just curious.
That is the same amount of propane that I go thru. My cabin is about 3200 sq. ft. When we are not there we set the thermostat at 55 degrees and also have the hot water heater wired to a switch so we can easily shut it off when we leave. The windows are old so we lose some heat there. I sure wish I could get down to 300 gallons but I know that won't happen.
Also LP hot water heater & dryer. I have Pella windows & doors through out & installed inside insulating windows. House is somewhat new about 10 years old. But same as you I don't know what else I can do to conserve on LP use & sounds like probaably not that bad since you turn yours down to 55. Thanks for info.
