mjkaliszak
Just thought I would post this, I smashed in my belly pan just under the clutches on a rock several years ago. I was able to smash it back out enough so it didn't rub but never could get it pulled out. 3 years later ( today ) I removed the rivets holding the seam together and drilled some puller holes, then hooked up my come-along to the sled lift frame. Worked out well enough to share the idea , if anyone else has the same condition. It is a must to remove the chassis rivets and pull the plates seperately.
