I believe you need 2 regulators. one at the tank ( high pressure) and one before it enters your building.(low pressure). we just hooked up a buddies furnace in his garage and thats what we had to do to get it to work proper. Not sure if they have ratings on them as far as pressure. Need to ask hvac guy.
you are better off calling gas co. and getting a 125 gal pig tank for fuel.tried using a 100 pounder when i set my garage up but went thru it to fast.cost me an extra 50 bucks to drop tank ,proper regs. and leak test all connections
You are asking how long it will run and that would require ais 24x26 insulated wanted to keep it around 50 degrees
