RAM mounted Garmin GPSMap 60csx question
redbirds5
Hi All,
I've mounted my Garmin GPSMAP 60Csx GPS onto my 01 MXZ with the RAM handlebar system. You have to use the belt-clip 'button' from the GPS to secure it to the RAM cradle using a hex tool and screwing it in - no big deal, but the unit doesn't tighten completely and just rattles/vibrates in the cradle; has anyone else ran into this problem, and if so - how did you remedy it?
Thanks in advance!
TDMXZ600X
fgsacts
I have the same set up and mine is tight with no rattles. Sure you have everything together correctly?
Longlegs
Is it the button that didn't tighten up? Mine was stripped out so I JB welded it to the GPS. Mine is very tight in the cradle, almost wonder if I am going to break it getting it out.
