iceman_1347
Ok, so began the tear down of the skid last night to put my new track on. Everything was easy except for pulling out the drive shaft. We eventually got it but now that I'm ready to put the new track on what is the easiest way to put the drive shaft back in? We had troubles on the clutch side of getting the plate with the studs out of the way to get enough play to be able to get the chaincase side bearing off when taking it apart. Is the easiest thing to put the chaincase side in first without the bearing in place so that we can get the clutch side in place and then push the chaincase side bearing on afterwards?? This seems like it's going to be a beast.
