rebuilding xlt need bolt torque specs
bestfib
I am rebuilding a 96 xlt sp 600, and need to know all of the bolt torque specs. Didnt know if anyone knew of a good website for this. I had a crank bearing go out and tore it down to the last bolt and now putting back together. Any tricks or ideas or websites would be appreciated. thanks.
bestfib
thanks, unfortunately i live in central illinois and not to many snowmobile dealers around and the 2 i have talked to are jerks and dont want to give any info. i went there one time for a simple choke cable and the guy acted like you had to be a certified polaris mech. before attempting to do such a hard task. he was lucky i was in a pinch cause i would have gone somewhere else to buy it. never went back though.
knewt66
i found this
Cylinder Heads - 8mm bolts - 17-18 ft lbs
10mm bolts - 24-26 ft lbs
Crankcase - 8mm bolts - 17-17 ft lbs
10mm bolts - 23-25 ft lbs
Cylinder stud nuts - 24-28 ft lbs
found this on another sight
bestfib
thanks, does it say anything about flywheel or clutch? i imagine as hard as they were to come off i dont really have to worry to much about them. just dont want to overtighten. thanks again.
xcr800
My Polaris Master Manual says flywheel is 60-65 ft lbs and clutch bolt is 40-45 ft lbs on the clutch bolt. I would put some loctite 242 it is the removable blue stuff. Hope this helps
