Just replaced oil line in F7 after belt blew and cracked oil line. What is the best advise to make sure there are no air bubbles in line blocking oil flow? It appears there is no oil in line, but want to make sure.
Oil lines should "bleed themselves" because of the draw from the crankcase. However if you are at all sketchy about this, run some pre mix in the tank.
Hold the lever to the full throttle position on the oil pump, with the motor running at idle. The bubbles should pull through in a minute or two. Yes, it will smoke a lot, but wont hurt it.
