Trying to trace down detonation issue on my 2010 800Ptek and I'm now thinking that my 30:1-32:1 oil mix is the root cause. Could this be possible? Will adjusting to 35:1 or 40:1 cause more fuel to enter the combustion camber?
No. It will only cause more oil to enter the combustion chamber. The fuel system functions independently of the oiler. Pre-mix ratio will affect air fuel ratio to an extent, but only on a pre-mixed motor. Are you pre-mixing, or just referring to adjusting oil pump flow?
No pre-mix, using the oil pump.
But 40:1 would cause less oil not more oil into the combustion camber, correct? I was thinking this would cause more fuel to combust and more fuel=cooler burn and less chance of detonation....
Correct, 40:1 = Less oil. 30:1 is a tad on the oil rich side, but not enough to change air/fuel ratio to the point of causing detonation. Something else is going on. I would be looking closely at your crank seals. I seem to remember a known issue on one side or the other(can't remember which side) on the Ptek motors. Also carb boot issues were common on that motor.
Also, check out your DPM system. Now that I'm thinking about it, I seem to recall an issue with the spool valve on those things. Dootalk.com has a ton of good info if you haven't been there yet!
It still ran, just would cut out at certain RPMs and throw a engine light once in while.
The check valve was hard to see as it was low and in-between the exhaust and engine. I just happen to look in there with a flashlight when looking for a exhaust spring in the bellypan
