I'm rebuilding my secondary clutch on a 2004 Polaris 700 classic. First, if someone could confirm the difference between the TSS-04 and TSS-98 is the 04 has 4 bolts holding the helix and the 98 has 8? I have 8 bolts.
1) When I was taking the secondary clutch off I noticed it slides back and forth on the shaft about an 1/8". I didn't notice this before, is this normal? The hold in bolt was tight.
2) Is there a trick to installing the moveable sheave bushing? It is a pressed fit and the sheave material flexes pretty easily. I'm afraid I will damage it if I press to hard to get it back in.
3) I was thinking I would rebuild the primary clutch too. I went on Team Ind. website and I believe I found the kit for my sled, but if I could determine if I have "wide rollers" that would positively identify the kit number (940153). Does anyone know how to distinguish wide rollers or not?
Thanks, Pete
Thanks, Pete
