I have a 2000 Mach Z 800 that I bought used and the guy put a SC10-3 rear suspension in it from a 03 or 04 Rev. I need to replace the shock at the rear and my question is how can i tell if the shock has 18mm bushings or 8mm bushings? I dont want to order the wrong shock. How do you measure with the mm size? Will the 8mm size bushing be smaller than if i held up like a 10mm socket to it to compare? On the other hand a 18mm socket is huge and cant imagine bushings being that large? Any help on this is appreciated.. Thanks!
Dan
Dan
