Ski-Doo 600 SDI Belt Noise?
sledheadjoe
I ride an '04 Doo with 600SDI engine. Last weekend, I bought a new Dayco belt and installed it before my ride. I adjusted the secondary cam back to position 1 for proper belt height. Once on the trail, I noticed the sled seemed to be much louder than normal but I continued, making sure to break it in properly (under 50mph for the first 50 miles varying speed). The noise wasn't a squeel, but more of a howl. After my 200 mile day, the noise seemed louder than at the start. It was loudest between 25-40mph, particularly when slowing down from a long straight stretch or speeding up from a stop. I'm almost sure it was coming from the belt, but after the ride, I put the original belt back on and the noise was still there. I switched between my sled and my wifes '05 600SDI just to make sure I wasn't imagining it but hers definately didn't have the same howl. Checked all my skid bearings and they seem fine. I'm not sure the best way to check the drive bearings other than visual inspection.
Any ideas?
-Joe
longtrack
did you check the Chain case Dip stick for Metal and have you changed the Oil in it? Have you Greased the Bearing under the Driven Clutch?
You have a Bearing going out somewhere.
sledheadjoe
Thanks for your response, longtrack!
I changed the chaincase oil during the summer. Checked the dip stick on the trail and very clean with no shavings. Did a quick tension check but it was also perfect.
I also greased the bearing behind the secondary during my summer maintenance, along with every other zerk on the sled I could find.
Any other thoughts? Heading home next weekend for a 4 day trip and don't want problems.
-Joe
