ski doo short block
peter
Anyone where I can get a rebuilt/new motor for a 06 ski doo 800. Motor went down over weekend took motor out upon inspection, best for me to get a short block. When motor went down it took out piston, crank, and cracked the lower case.
jimfsr
SBT has short blocks, also available from ski doo dealer. Just a note though.. the OEM re-built has no warranty unless the dealer installs it. Ask me how I found out...Plus most will want a core motor and if the case is bad the core is junk.
Also check Hildebrand marine, I see thay advertise re-built motors.
dab102999
Ya they will bust ya down for cracked case..might want to try MCB performance out of michigan...i think he deals in shortblocks now too.
peter
Any idea what caused the destruction? How many miles were on it?
From what it look likes bearing on connecting rod went and chuck of something got cought up and cracked lower case. Made loud noise thinking my belt went, but then motor stopped fast. There is 8500 + miles on it.
Done it may times, Have cases welded. Install remanufactured crank from skidoo, bore cyl and install new pistons. Done. You just have to find someone to weld the cases and get cyl. bored
renegade
And a new crank was only 450 bucks with a core return. I thought very reasonable. Mine was a 700, but prices shouldn't be to much differant.
